What did you do with your Allis Today?
 Post Reply Post Reply Page  <1 222324
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 11:00am
This is what I did with my Allis today! Big smile
(She drove for the first time in at least 40 years I'd say, off the trailer onto the driveway at last)
Edited by ekjdm14 - 28 Jan 2025 at 11:03am
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 11:55am
Good to see it moving under its own power!
Mike, I just might take you up on that. I’ll keep that in mind as we get in to warm weather
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 7:27pm
Ran the spring tooth harrow with the wd 45 many many times over the field trying to level up from a rough plowing job
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 5:59am
I was just thinking of you yesterday. Needed a weight and spotted my small anvil on the bench. That reminded me of your plowing exploits.
Serviced the air cleaners on both 45's yesterday. Put the carryall on the wide front for a tractor ride Saturday. Got the 185 and planter out and did a test pass, all systems go just need dry conditions.... Got the 6080 out to remove the loader on D-17-1. Got that done without killing myself. Left the mount brackets on for now.
That tractor will be sold at some point in the future, not sure weather to sell with the loader on or separate them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2025 at 8:35pm
On the 170, replaced the cross over shaft assembly for the traction boost control. The original was siezed and broke the shaft end off where it connects to the 3pt. Got it from L&L
The 7040 got a pair of LEDs to replace the orhi/lo beams. Looking forward to see how they work in the dark
Got the 190XT running again after a tip from a forum member. Can go in to more detail on my other thread
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2025 at 6:16pm
Planted 13 acres of oats. Actually 12.67 acres. Ran one bag short. First time using the mounted all crop grain drill. Learned a bunch. Thought i had it ready to go. I was wrong. Hooked up the support chains. It never occurred to be that the previous owner maybe had smaller rear tires. I hooked up the chains, lowered the drill and was a couple inches short of the ground. Fertilizer rate is more of a very broad range. New winter project part two
55allis View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2025 at 7:13pm
I went and harvested (not really) with the ol 410.
Think I have an overkill of a tractor? Needed my duels on for the picture!!
Really was just was moving the harvester.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 38 minutes ago at 7:20am
Planted corn like it was 1985!
