What am I ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: What am I ?
    Posted: 14 Dec 2011 at 2:24pm
Ok guys..test of the day...
Make,model and year >
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 2:31pm
   Rumely "Oil Pull" Model G 20-40, I think.
http://www.rumelyallis.com
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 2:33pm
That's easy the year is 2011!  :-)
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 2:36pm
   Oh year, 1918-1924.
coop97 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 3:02pm
1919 Model H 16-30
56 WD45 DSL,55 WD45 DSL,53 WD45,50 G,48 C,37 A,30 E 25-40,28 E 20-35,79 5030
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 4:03pm
Could it be a 1938 flower pot and vine arbor from France? That's what it seems to be used as!    hee hee!
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 4:27pm
I'm with Rfdeere ,    Rumely..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 4:31pm
   Coop97 is right, It is a Rumely "Oil Pull" model H.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 5:36pm
A LOT of work is what I'd call it.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 6:09pm
Better grab it, they are impossiable to find
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 6:23pm
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 6:57pm
Great guys ! Now I gotta find the  guy that took the picture to ask where he was to see if I can 'acquire' the old beast.
One day I might figure out HOW to get pictures to 'magically' appear in the message too...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 7:06pm
Jay, you find the Rumley and buy it, and I will give you 1 on 1 instruction on posting the pictures of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 7:12pm
Posting Pictures
To post a picture from your computer, first click on  new topic + or post reply/ . Do not use the quick reply box at the bottom of a previously posted topic. At the top of the box that opens is a row of icons. In the middle of that row is a picture of a tree, click on it. A window that says image properties will open, if that window is small, maximize it so you can see everything in the window. Click browse and find the picture on your computer and open it. Click upload and a small window will open asking you to be patient, click OK in the small window. The picture will appear in the box on the lower right side(if not click preview). Check the width and height of the picture. If the numbers are greater than 800 wide and 600 high, the picture will not be seen completely on the forum. You can change these numbers but need to keep the ratio the same between them or the picture will be stretched. Click OK at the bottom and the picture will appear in your post. You can add text to the post before or after uploading the picture. It is easier to insert your text first. Now click post reply or post new topic and you are done.
 If you have your pictures on photobucket.com, you can go to the picture in photobucket  and copy the IMG file and paste it in with your text. This is the better way to do it because if you upload from your hard drive to this site, you will shortly run out of space and have to delete older pictures. Once deleted, they will no longer show up on your old post.
  I personally use Picasa.com but I have to add the brackets around the picture url.
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 7:21pm
could  that look like an allis b fender and steering wheel behined that giant boat anchor?
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 7:34pm
That is a good eye my friend, I think you are spot on!!!!!
Still in use:
