WF |
automaticdave
Joined: 20 Jan 2011 Location: Granton, ON Points: 259 |
Topic: WFPosted: 27 May 2017 at 4:46pm |
Has any one stuffed a 226 into a wf ?
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5095 |
Posted: 27 May 2017 at 7:24pm |
Basically, all you have to do is replace the 4" stroke crankshaft with a 4.5" WD45 crankshaft. If you use 4.125 pistons, you will end up with 240 cubic inches and, from the outside, it will look identical to the stock 201 engine.
Matt -mid-mich
Joined: 30 Jul 2014 Location: Chesaning mi Points: 92 |
Posted: 28 May 2017 at 6:01pm |
I have a 226 in a wf I pull with you will need to shorten crank shaft I think was and inch and had to ream out crank pulley some and use the water pump from old engine by re drilling holes
We have 86400 seconds to everyday make every second count because we never know when it's our last
