Welding Rod
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 12:33pm
6010-5P is a DC rev polarity rod and a root pass rod .
6013 is a mild steel all position and general purpose weld but has a heavy flux cover after welding with medium to low penetration , not real good on dirty or old metal with rust.
6011 will give a deeper penetration with less amps needs and a weld easily cleaned for multi-pass welding, less prep and some dirty or rusty metal can be joined  .
7014 is not a true low hydrogen rod but gives a weld much like 6013 with higher tinsel strength 7024 is a drag rod with heavy flux coating for flat work where arc is maintained with flux in contact with work so no gap is needed to be maintained by the welder. Cosmetic good looking weld with low penetration
7018-AC or 7018 is preferred by many as it has a flux that is easily removed and gives a sound high strength weld and has a good appearance visually. A clean work surface is needed
 Welding is practice, practice, practice.  good prep and proper heat
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 2:14pm
Originally posted by DaveKamp DaveKamp wrote:
Yeah.  Last time I had to do it, I shorted the coathanger enough to red-hot it, then dragged it through the sand under a buddy's boot... did a pretty good job of cleaning it off.  We sacrificed a piece of tubing from his hydraulic jack handle to slip inside a ripped-apart tie-rod, and then ratchet-strapped the wheels together to suck it in close enough to zap back together on the trail.  It wasn't pretty, but it got him patched up just well enough to creep back to camp.
You probably learned that from the TV show, what was it, MacGyver? Yea, the electrode fell off the plug so he welds a piece of nail on it with 12 g wire.
[TUBE]PqXkjYcHmY0[/TUBE]
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 7:44am
Been working alot finally got a paid day of rest. The only time a ac machine and rod out performs a dc machine and rod is when the carbon steel has become magnetized. Dc always makea better pretty welds until that happens.es 70 mig wire is as close to a 70-18 rod as you can get.
Edited by mlpankey - 27 Aug 2012 at 9:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 10:15pm
I am stunned!!  The WEALTH of knowledge on this forum is simply amazing!  I got more than I asked for and  I learned a LOT!  THANKS Allis family!
Edited by Ted J - 27 Aug 2012 at 10:16pm
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 10:25am
6011 root pass followed by 7018 here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 11:57am
6011 is great for leaving sl*g in the middle of the weld bead.
