Welding Rod |
Page <12 |
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41980 |
6010-5P is a DC rev polarity rod and a root pass rod .
6013 is a mild steel all position and general purpose weld but has a heavy flux cover after welding with medium to low penetration , not real good on dirty or old metal with rust. 6011 will give a deeper penetration with less amps needs and a weld easily cleaned for multi-pass welding, less prep and some dirty or rusty metal can be joined . 7014 is not a true low hydrogen rod but gives a weld much like 6013 with higher tinsel strength 7024 is a drag rod with heavy flux coating for flat work where arc is maintained with flux in contact with work so no gap is needed to be maintained by the welder. Cosmetic good looking weld with low penetration 7018-AC or 7018 is preferred by many as it has a flux that is easily removed and gives a sound high strength weld and has a good appearance visually. A clean work surface is needed Welding is practice, practice, practice. good prep and proper heat
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
You probably learned that from the TV show, what was it, MacGyver? Yea, the electrode fell off the plug so he welds a piece of nail on it with 12 g wire. [TUBE]PqXkjYcHmY0[/TUBE]
mlpankey ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Been working alot finally got a paid day of rest. The only time a ac machine and rod out performs a dc machine and rod is when the carbon steel has become magnetized. Dc always makea better pretty welds until that happens.es 70 mig wire is as close to a 70-18 rod as you can get.
Edited by mlpankey - 27 Aug 2012 at 9:11am |
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
I am stunned!! The WEALTH of knowledge on this forum is simply amazing! I got more than I asked for and I learned a LOT! THANKS Allis family!
Edited by Ted J - 27 Aug 2012 at 10:16pm |
Rawleigh ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
6011 root pass followed by 7018 here.
6011 is great for leaving sl*g in the middle of the weld bead.
Page <12 |
