Welding Plow Beams ?? |
Larry Miller ![]() Orange Level ![]() ![]() Joined: 21 Nov 2009 Location: NWIL Points: 909 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Jun 2012 at 8:51pm |
Live and learn - Finding you cannot weld AC plow beams and get any strength at all w 6013.
Will any rod work or must I use bolts for any connections ? Trying to make a 3 pt carrier from a scrap plow. I think I can do it with bolts - after I cut the welds out and match holes. Glad I don't have to make a living working in the shop. Thanks for any suggestions. Larry Miller
I used to be young and stupid, now I am not young anymore.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87932 |
THe material is high strength steel. I dont know exactly what it is. I cut the beam as needed and VEE notched so i could get full penetration. Preaheat the steel to 200 degrees with a propane or accet torch. Weld with 7018 rod, several passes. Chip out the flux good between passes. YOu must get full penetration. I also added a 3/8 reinforcing plate on the side in the high stress areas.
I took the beam and cut two long pieces off of it and welded one onto each side in the first photo... in the third photo you can see the 3/8 plate probably 8 inches long that spans across the welded joint as a stiffiner. I reused the vertical plate to make the top link attachment for a 3 point... Kids wanted a 3 bottom plow to use on the JD 3020. Way to big for my little B !
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
It can't hurt to post heat the area also and wrap it in insulation to let it cool as slow as possible.
