welding cast iron
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Topic: welding cast iron
    Posted: 12 May 2012 at 9:03pm
Does any one have experiance welding cast iron.
I've come across the first damage piece on the WC.  The cast housing on the PTO is cracked around the lever for engaging it.  I understand the difficulties in welding cast but seeing the piece is trash and won't even hold oil at this point.  I'm not out anything to try and fix it.  Where it is located it should never see much stress.  And would be easy enough to replace anytime if I'm wrong.
we have a stick welded. any advice on proper rod and settings?
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 9:12pm
Vee out and use nickel  rod  (ni rod). Make short welds and ping to stress relief  .take it slow .  Can be pre heated  and brased or weld with bare cast rod  using a torch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 9:21pm
Thanks I'll give the nickel rod at try.  I haven't done brazing since high school and wasn't too good at it then.  I'd be worried about over heating.
dscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dscott Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 9:35pm
Allow to cool very slowly. Also protect from cool blasts of air say from a door opening or what have you, sudden tempurture drop may cause your repair to crack.
ncrc5315 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ncrc5315 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 11:32pm
What I have done to weld cast, is to use a rosebud torch head, to heat the back side of the piece of cast I want to weld, till the front side glows cherry red. Weld a few inches with nickel rod, then reheat from back side, then weld a few inches. This has worked for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 11:51pm
When you have it welded. Cover it with warm dry sand or lime. Slows cooling to prevent cracking. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 5:55am
Sounds like some experiance has been learned both good and bad.  It all sounds like good advice. I will back heat it and cook some sand to cover it it when I'm done to leave it in.
I figure its a good piece to learn on as if I can save it great if not.  I'll track down a used housing.
Thanks
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 7:09am
I like the old fashioned way -- brazing -- that said if you have a good welding supply shop in your area they can set you up with the right rod and temp stick to make shur you are pre- heating to the right temp. Also Tracy M has great advice on slow cooling As a young guy I once helped weld sprocket rims for a D-8 cat and my job was to pre heat and then  cover the weld with floor dry so it would cool slowly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dscott Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 9:24am
            Do you have an old  exhuast manifold around? If you do, practice on that. An old ford manifold is what I tought myself on. A few tips, if your peices fit together nicely tack them good on the edges before you vee it out, and when strike your arc in the center of the vee'd area then quickly move to the desired starting point(this helps keep from making porous and unsightly starts and restarts). Welder setting vari by machine but a good place to start is 1 amp per thousanth of rod diameter.....IE... 1/8 inch is .125 so start at 125 amp reverse polarity, this formula works for most the electrodes I've used, 7018, Nirod, 680 Eutectic are just a few.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 9:41am
By reverse polarity do are you refering to a DC welder?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dscott Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 10:01am
Yes, positive to the ground clamp. If you read the package the electrodes come in most reccommend the polarity sum rod welds better @ staright polarity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 10:07am
Just find another PTO box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dscott Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 10:08am
Ac machines are not subject  to reversing polarity as the ac(alternating current) alternates between positive and negitive as a matter of design.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 10:10am
If it is a area that has a bore or seal then rather than welding i would look at brazing and flowing brass into crack.
 On other areas the welding with a SS rod or a selected cast iron rod would be the choice. I use Allstate #8 for most cast. Watch so you do not overheat rod with to high amp flow also. V out base material to allow good penetration , if welding from only one side it's real important the root pass is to almost out the non ground side , just short of melting through .
 You can use old fiberglass or rock wool insulation it protect from cooling to fast also . less cleanup than sand .
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 11:03am
When I weld cast iron I usually pre heat the casting to about 400 deg. in the oven (kitchen stove).  After welding it goes back into the preheated oven and then let it cool in there. Slow cool and no drafts.  (I can get away with this as I have no wife around to give me grief about it!!!LOL
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 11:26am
You can torch weld it using braising flux with old cast iron piston rings.  You then end up with cast iron on cast iron.
Edited by Dick L - 13 May 2012 at 11:27am
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2012 at 11:41am
A gas grill is also a preheat/postheat option.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2012 at 11:54am
Something I had read about for years and just recently tried is a MIG welder with ordinary mild steel wire.  Worked better than any process I have ever tried in the past. Heated things up first and welded the part back together with short beads and no special cool down methods.  In fairness to other methods I had tried an old timer recently told me to NEVER bevel or clean the broken parts with a grinding wheel, always use a carbide burr. Something to do with smearing something or other on the surface of the iron?
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2012 at 3:49am
I agree with Dr. Allis.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2012 at 5:45am
I know this is not what you want to hear, but I had one like that. It is a freeze crack fro water setting. There is no structural strength needed in that spot if it was like mine. I just cleaned mine good and JB Welded it on both sides and is still holding to this day.  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2012 at 8:02am
Lots of responses and good ideas.  I'm sure this is one of those things that has more then one way that works.  Some of which has to do with the experience of the person doing the work.
As I'm most comfortable with arc welding this is how I'll tackle it, this week end.  I could see how brazing might be better heat distribution wise but I'm not as good with getting a consistent and strong joint.
As for replacing since this is an easy to remove part I feel this is a good piece to learn this skill on (may need it some day for the working tractors).  I'm resigned to needing to replace the part... but if this works so much the better.
the damage does not happen to be freeze damage as far as I can see. There is a radial fracture around the engage lever about 1" from the base about 40 degrees worth.  It will need some level of strength. It appears to be that it was beat on or something heave was dropped on the level where the rod connects.
I'd put my odds of success at 75%
BTW I'm loving the JB weld to finish off the rods and levers, fills the pits I can't sand out and is strong enough to stay with the flex they will get.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2012 at 11:44am
some good reading here
i have had good luck with their cast rod also.   built up main clutch bearing release housing on HD10W.  machinist said was best cast weld he ever machined and im no pro
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2012 at 8:34pm
I'm with Butch on the grinder. DONT USE IT! The disc is put together with fiberglass and resin to hold the abrasive together, and it will contaminate the weld. Anyone who has taken an AWS certification test will tell you that. Go with the carbide "roto-file" or a wire wheel on a drill/grinder to remove metal or clean the weld area. Getting it clean goes a long way. Also +1 on the mig welder and short beads. Much less heat that way. It's all about expansion/contraction with cast. Less heat or even heat and cooling, and you're OK. If you're going to use the stick welder, I recommend cleaning well, preheating, then running short beads, with a good cleaning between beads. Less temp change that way. My .02.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 10:21pm
So here's the results.  I bought the cast rod along with other things.  I realized after the fact it is $5 a rod.  hmm $30 on a weld that might not work.  So after figuring I'd buy a used part, I took standard 7014 for the heck of it.  Welding 2" at a time no special measures and no special cool down (The cast rod instructions called for none, clearly labeled on the packaging).
Though I would not recommend for a one of a kind piece my throw away piece is now restored with a little cosmetic work still required. I did use a grinder as any contamination would be miniscule and I'm not building a structural building to spec. most contamination is burned off in the arc.
Stress test shows to be a solid weld(any higher pressure would break the cast itself).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 7:33am
On a larger area one can weld the root pass with the cast iron rod, then weld edges of metal also with pass from cast iron rod, finish the weld with E-7018 or E-70S wire as they will alloy with the cast rod buttering and complete the fill in welded joint.
This page was generated in 0.333 seconds.
