WD45-D17 Crankshaft?
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Topic: WD45-D17 Crankshaft?
    Posted: 21 May 2010 at 6:34pm
Will a WD45 crankshaft interchange with 1958 D17,gas engines?TIA.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 6:35pm
no the mains thrust in different locations.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 6:39pm
Explain please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 6:57pm
d17 crank is supported by 3 nonadjustable precision insert type bearings the endplay or thrust is controlled by the center main bearing. A wd 45 uses bearings that require shimms and the thrust or enplay is controled in the front bearing . The front bearing must be installed with the notch inserted over the pin in the block . pin keeps insert from turning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 8:41pm
And the D17 mains are 3.00" inch diameter and WC-WD-WD45 are 2.500" or less...no way to interchange them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 10:54am
Thanks guys!
This page was generated in 0.081 seconds.
