Wd45 wheel weights |
Allis-chalmers wd45 ![]() Orange Level ![]() Joined: 11 Apr 2012 Location: Newton, Nj Points: 1917 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Jul 2012 at 10:21am |
Is it worth me picking up a set of rear wheel weights for my wd45? Fairy cheap will they help with wheel spin at all?
XT in pa ![]() Orange Level ![]() ![]() Joined: 21 Apr 2011 Location: hickory pa Points: 711 |
depends on what you are doin to get wheel slip?? might take two or three sets .
Shawn |
190XT,D17and 7045
Just discing I just got a set for 50
KGood ![]() Orange Level ![]() ![]() Joined: 17 Nov 2009 Location: Logansport,IN Points: 955 |
I,d put them on and I agree 2 or 3 sets would be better. Are you able to use the traction booster?
I'm not sure if it's working I don't think it is how would I fix it?
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
It depend what kind of disk do you have. you'll need a snapcoupler disk for the traction booster to provide any assistance.
Okay I'm jut using an old jd pull type disk
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
fluid in your tires will add about 750-900 lbs depending on size
Okay I'll see what happens. What f&h weights. We're meant for a wd?
