Wd45 wheel locks
D14JIM14 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 wheel locks
    Posted: 21 Jan 2021 at 10:50am
I have heated , hammered impact wrenched and long bar , but I can't get these locks turned to loosen the wheel rails !!
This tractor sat 30 years and this tire went flat and spilled calcium all over the rim sometime during those years .
The rim is salvageable but I can't get the wheel out to clean the rim up well .
I'm about ready to cut the wheel locks out and get new used ones . Any suggestions ??
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 11:22am
Did you heat the right end? The thread is near the head and the rest of the bolt is just a smooth rod/pin.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 11:27am
Take the tire off the tractor and lay it on the ground.  Remove the eight bolts holding the eccentric on the center.  With a large hammer and a piece of wood smack the center until the center and eccentrics fall out.   Be sure to gather up the four eccentric pieces that go between the eccentric and the rail.
Put the eccentrics in a vise.  Using a torch, 1/2" impact and a hammer and drift, just keep working at it until they come loose.  There are keeper spring washers on the back of the eccentric bolt that you need to remove before beginning working on the.
I have also heard of putting them into a wood stove to get them loose.  I've never done this so I cannot comment on it.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 11:36am
Thanks Dusty and John .
Heated the correct end .. I've had them be stubborn before but not like this !
John, I'll get a 2x4 and a BFH and see what happens .
Thanks again ! Jim
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 1:01pm
Have you tried unbolting the clamps from the center?
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 1:09pm
Yep but wheel is tight ! Loke CV I said a big hammer . Will let you all know how it goes when i get home and work on it again .
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 2:58pm
As always with calcium in the tires: It's not if they will leak, but WHEN Thumbs Down.  Also how much damage will it do when it does.
   Once you get things apart, and the tire dismounted,  heat the rail directly where the stop bolt is and then you should be able to remove the stop bolt.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 3:27pm
Beat the wheel out and eccentrics are soaking in pb blaster . Will put in a vice tomorrow afternoon and start trying to turn !
Huolti View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Huolti Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 9:18pm
Had same problem with eccentrics.Got them off the rim and hub and then used heat and a small hydraulic press. Finally broke loose.
fleeter allis fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fleeter allis fan Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 10:00pm
It is important to remember that when you heat two components that are rusted and frozen together, you are attempting to expand one component in relation to the other. If you heat the entire assembly, both components expand at a similar rate (assuming both components are made of the same material) and you often don't get far. I have had some success using water or even ice to try and keep one component cool while heating the other. That way, the coefficient of expansion of the two components is different and you can hopefully break them free.
I'm a man...and I can change...if I have to... I guess.
'44 B, '46 WF, '49 G, 810GT, 916H, 620
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2021 at 8:58am
Got the eccentrics apart !!
This tractor has 2 stop blocks on one rail . One I heated and got out, the other the head rounded off with a 6 point impact socket ! Gotta work some more on that one !
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2021 at 11:22am
Be careful with heat on a rim.  The tire will explode from very little heat.  There was a video someone posted on here.  It was pretty scary!
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2021 at 11:48am
Just did this on a WD, definitely unbolt the clamps from the center piece and hammer the rim and clamps off. Then go at freeing up the clamps with heat. Wasn't too bad, lots of heat and hammering.
