WD45 vs. WD Seat Bracket
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 vs. WD Seat Bracket
    Posted: 12 May 2010 at 4:32pm
Is the seat bracket on the WD45 supposed to be the same as that on the WD? The bracket on my '45 curves down to attach at the front of the right brake housing cover. The seat adjustment bracket (short-long legs) is curved to match, so my guess is that the seat bracket is supposed to curve. On my friend's WD, the support is not curved. I don't (yet) have a parts manual to check on this. Thanks much!
WC, CA, D14, WD45
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 4:40pm
They are different,  the WD doesnt curve, has different bushings and shock and mounting plate.   I cant remember if later WDs with the 45 style of trans have the WD 45 seat bracket or not.  I have  a later WD, but have been on it for a long time, cannt remember.
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 4:42pm
The WD45 seat bar is curved. The bracket that goes over the brake cover has 3 bolts. 2 go into the brake housing, top side, one perpendicular to the others at back of the housing. That one is just below the lower shock mount.
1954 WD45 NF "Iron Tater"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 4:46pm
Thanks, Skip and Jeff. I've been looking at my seat support as the seat feels too far to the right - touches the right fender. The bushings appear to be shot, both those where the support attaches to the cover and those at the top of the shock absorber. Are those readily available? Thanks again!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 4:47pm
More pics of WD45 seat bracket:
Mike(SEIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(SEIN) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 4:51pm
Yes,They are available from many of this site's sponsors , I got mine from Doc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 5:25pm
Thanks Mike.
WC, CA, D14, WD45
