WD45 shifter pin dimensions
WD45 Aaron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Topic: WD45 shifter pin dimensions
    Posted: 11 Apr 2022 at 8:50pm
 Anyone have a shifter pin laying around that they could take some measurements with calipers? I've got a WD45 with a shifter that can be rotated any way that you want. I haven't pulled it out yet, but I assume the pins are in the bottom of the transmission. With a few dimensions I can whip a set out of the lathe.
Thanks,
Aaron
Machinery rescue for all things rusty or broken. Current residents include 2-1/2 WD45s, Oliver Row 77 gas, Farmall super C, two Cat D2's, Clark C500-80 forklift, and a sick Kubota.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2022 at 9:08pm
Make them to fit your worn out parts.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2022 at 6:23am
You can buy oversized pins from AGCO and then grind them to fit you worn out shifter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2022 at 6:43am
Aaron,
Yes what Mack and the doctor mention. I tend to build them to fit. I had to customize the head shape to fit the slot in the shifter ball. till you pull it apart you wont know how bad things are.
Yes a broken. worn or missing pin can cause the shift lever to be all over but there also may be many worn areas in the lever, the seat and even in the shifting forks. It is a pain to take the shift tower off but most of these tractors are in need of some love in the shifter area. Age and abuse and normal wear for 65 years may need attention.
Several threads on here about repairs to bring them back near spec.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2022 at 7:53am
One of the slots in my lever was badly worn and not straight. Took some welding/grinding/fileing to get it fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2022 at 11:17am
All,
I appreciate everyone's input. I will examine the situation once I get it torn apart. I would still like some dimension so that I have a starting point. Reading various sources the pin diameter is .250" and the standard size square head is .325". What I don't know is the overall length and the length of the square head.
Thanks,
Aaron
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2022 at 7:20pm
IIRC the width of the head was about .25 and maybe the length was .325? If you called Brenda at Sandy Lake (as an example of a dealer) I bet she could give you dimensions?
I just took a hex head bolt (.25 dia) and ground the sides of the head to fit the slot, and cut the length to fit also. the length can stick out the hole/s.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2022 at 8:50pm
You will need to start with a bigger bolt and redrill the pin hole. It will be sloppy in every direction.                           MACK
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2022 at 11:29pm
Drill out the hole straight, and continue on through the other side for a second pin and cut second groove in ball of shifter.
  While at it, check the gates and weld up the end of the shifter to fit the space better so it doesn't have a chance to slip through the gates.
  On one shifting tower, it was worn pretty bad so added a stainless steel washer under shifter ball and concaved it to fit between the wear of the tower and the ball... hold-down washer and snap-ring were then a snug fit.
 Shifter never felt loose after that.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2022 at 4:40am
I've got a set of brand new over-sized pins here for 13.00, plus shipping, if interested. No need to go through all that trouble...let me know...Rick
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2022 at 9:27am
I'd get those pins from Rick wile the getting is good!
When I did mine, it was and still is a single pin model. I used a reamer to get a nice fit on the tower and built up the slot and filed to fit the oversize pin. Works great!
