WD45 PTO |
Isonm
Joined: 16 Jul 2014 Location: Mound City, KS Points: 10 |
Topic: WD45 PTOPosted: 19 Dec 2015 at 9:44pm |
I have one of the WD's made at the end of the model run which was fitted with a WD45 rear end. Serial number is WD but it has the curved shifter and a WD45 rear end. My problem is with my PTO. It is always on and will not disengage. Any help, suggestions, etc. would be appreciated.
dads45
MACK
Posted: 19 Dec 2015 at 9:57pm |
First thing to check is set screw on lever going into PTO box. Could be loose or gone. If not that, not hard to drop box and look inside. MACK
Isonm
Posted: 19 Dec 2015 at 10:07pm |
Thanks. Have checked and set screw good. I guess I will have to drop it and take a look as suggested but I hope the problem will be obvious since I am not sure what I will be looking for. I see the pictures in the manuals but not sure what would be causing the problem. Probably a good thing to get inside and get an education anyway. Thanks again.
dads45
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 19 Dec 2015 at 10:15pm |
See if someone can post a picture of where the arm should be with the PTO disengaged. I've seen the set screw come loose and the shaft gets off enough that it won't work right.
AaronSEIA |
Isonm
Posted: 19 Dec 2015 at 11:35pm |
Good idea. I will check out if I can turn the shaft with the set screw loose to see if it will get to a position where it will work or if I do have something going on inside the PTO. Thanks.
dads45
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 20 Dec 2015 at 3:56am |
See pages 238,239,and 240 of the attached link. The Gear item 7 slides on the shaft to engage and disengage the PTO. It may be seized to the shaft, Gary http://www.grandpastractor.com/manuals/ac/WD-WD45/wd45-parts-book.pdf |
ac45dave
Posted: 20 Dec 2015 at 7:08am |
Edited by ac45dave - 20 Dec 2015 at 7:11am |
Isonm
Posted: 20 Dec 2015 at 8:11pm |
Thanks. Very informative, good exploded view, and parts listing.
I noticed you are located in Peterborough, ON. and have to say I spent a week in your fine town taking a strip canoe building class from Ted Moore at Bear Mountain Boats. Enjoyed the city, the lift lock, and had a nice time altogether. Again thanks for the link and info. on my PTO problem. |
dads45
j.w.freck
Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
Posted: 22 Dec 2015 at 11:27pm |
when pto box is off.ck the detent ball and spring.see if it will engage with a positive click.....
Isonm
Posted: 23 Dec 2015 at 7:18pm |
Thanks. warmer tomorrow, maybe I will pull it and take a look. Nice to have an idea of what to look for as I have never been inside it.
dads45
grateful1micelf
Posted: 27 Dec 2015 at 11:24am |
http://www.allischalmers.com/forum/forum_posts.asp?TID=112844&KW=wd45+pto&PID=910787&title=erics-1955-wd45#910787
not sure if i posted that link correctly? but there are some pics and a lil info on this thread, that is stuff i found foolin' w/my pto and hyraulics. just may give you an idea of what the guts look like. your issue is different than mine was, but hope it still helps you and hope you find your problem. mine was obvious ![]() eric |
1955 WD45 (1st and only tractor i've owned..for now)
