WD45 powersteering problems
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 powersteering problems
    Posted: 09 Jun 2015 at 6:23am
Neighbor has a WD45 factory power steering. Last week it suddenly lost all power steering assist to the right and about half the assist to the left. Has fluid, belt is tight, cant hear any change in pump sound when you try to turn it. Same at idle or wide open.  I think he has a problem in the unit?? Are parts available if I take it apart? Any common problems like his?
Thanks for any help.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2015 at 6:51pm
Butch, if you don't find help on here then send me a PM and I will help you out.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2015 at 9:44pm
I would say there is foreign mater in valve. A needle bearing comes apart some times and goes through alots of things.  MACK
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2015 at 6:59pm
O rings, gaskets, bearings, and seals I have purchased through Agco and bearing house. The gears in the pump would have to be made. Comes apart pretty easy and not to hard going together. The pump is the weakest link. could be the pressure relief is stuck open.
Good luck.
