WD45 power steering works in one direction? |
Post Reply |
Butch(OH)
Orange Level Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3831 |
Posted: 02 Jan 2021 at 6:19am |
I know that I have seen this posted before but could not find it via search. I have been hoodwinked into repairing a neighbor's WD45 with factory power steering that only works in one direction. I have never been into one of them and any advise or tips before I remove the unit and tear into it? Thanks in advance!
Orange Level Access Joined: 12 Sep 2009 Points: 19585 |
If it is factory power steering, don't yank off the control valve just yet !!! There is a "centering" adjustment that can be changed in chassis.
Butch(OH)
Thanks Dr! Yes factory PS and exactly what I was looking for, an easy fix Only manual I have is an IT. I assume that adjustment is external?
I've only done two of them in 40 years. There's a small cover you remove on the top side to access a bolt or screw to change the centering. Leave your hands off the steering wheel when you start it. You will be a hero when done.
Lon(MN)
Orange Level Joined: 11 Sep 2009 Location: Elk River,MN Points: 1907 |
For you it will be very easy. If the rest of the power steering unit is good, should take you 15 minutes to adjust.
MACK
Remove cover on both ends. Loosen bolt in end of spool, on other end, use a big screw driver to rotate spool. Screw cw or ccw until it steers same both directions . Don't take much. MACK
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8031 |
Is normal for them to favor one direction a little at start up. Be sure to have fluid warmed up before adjusting. It seems to change with temp. A little is a lot when adjusting. When its good hot it will likely still go one direction at cold start.....live with it.
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5642 |
The wisdom is priceless, but Darn... I was hoping to find a corny joke in this thread somewhere!! |
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11399 |
Guess it’s because we don’t know if it goes left or right? |
SteveM C/IL
Mine always went right at startup when set to work correctly when warm.....
john(MI)
Orange Level Joined: 12 Sep 2009 Location: SE MI Points: 9263 |
It must be a NASCAR unit!
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
I had the same problem with mine about 7 or 8 years back and MACK suggested I do the same to mine and it was spot on and had it working correctly in 5 minutes. Thanks again for that MACK.
1957 WD45 dad's first AC
Post Reply | |
