Wd45 power adjust eccentrics help!!
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 power adjust eccentrics help!!
    Posted: 15 Apr 2012 at 10:03am
I got my whole tire and rim off and have all the eccentric clamps off and I can't get the bolts un done I need some suggestions I tried soaking them in pb blaster and hammering on them but I can't get any of them loose thanks justin
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 10:14am
I've had the best luck lately just taking off the snap ring and driving the bolt back and forth until my impact wrench can start to move it. Then I use forward and reverse on the impact, all the time spraying any dry areas with pb blaster. If the rings are too corroded to come off, or the little saddles are rusted in to the point you can't remove them, I consider the whole thing junk and don't even mess with them....yes they can get that bad!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 10:20am
Okay well I have the saddles off and I've been soaking the whole thing in pb but I can't get the bolts to turn the slightest bit so I don't know what to do
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 10:25am
Where can I find new ones?
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 10:32am
  WE HAVE SOME ALL FREED UP    1-800-254-3116
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 10:38am
You have to use at least a 3 lb hammer, I set them on 4x4 blocks of wood and hit them on the back side until the bolt starts to move, then from the front, repeat as necessary. It does take time. If the saddles and snap ring came out you should be able to save them.
ALLIS EXPRESS!
This year:
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 10:38am
When I bought my WD it had a rotted out rim so had to change it.  Eccentrics were stuck when I pulled them off and didn't want to spend the money to buy new ones.  What I did was put each in a vice and using an acetylene torch to heat them and using gulf wax and penetrating oil along with a 3/4" socket (not the correct size, correct size is 25/32 I believe) and breaker bar was able to get them working very smoothly again.  Took about an hour each but worth it.
Leonard
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 10:06pm
Thank you everyone for the help! It's greatly appreciated will keep you posted! Justin
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 6:31am
A 20 ton shop press is easier than a BFH to get the eccentric pins to move in and out. Patience and persistance is the key....and lots of never-seize during re-assembly is helpful later on.
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 8:26am
uploads/583/Eccentric_Clamp_Disassembly.JPG
In absence of the shop press.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 9:39am
Good used original. $12.50 each. (they work good) 785-353-2392
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 9:51am
We also has some freed up available, but you should be able to get yours to loosen up.  PB blaster is not my favorite.  I much prefer sea foam, or deep creep (same company).
Get that snap ring off the back, and soak it from all sides.  Then a little "tapping" will cause slight movement and get the oil in even better.  Keep working at it. They will loosen.  Then as said, polish up and they will be good for another 50 years.
JimD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 9:10pm
Hey guys just wanted to say I got them working!! Thank you guys for the help- justin
