WD45 Motor Surging |
rustyorange45
Silver Level Access
Joined: 01 Sep 2013 Location: Vernon Co. MO. Points: 414 |
Topic: WD45 Motor SurgingPosted: 15 Nov 2016 at 6:17pm |
My WD45 is surging. I rebuilt the carburetor and it starts easier and idles better, but it surges at full throttle and I have to pull the choke out to keep it running. Carburetor, ignition, or governor? It was doing this before the carburetor rebuild as well.
Edited by rustyorange45 - 15 Nov 2016 at 6:19pm |
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Dnoym N. S. Can.
Posted: 15 Nov 2016 at 6:26pm |
Carburetor, intake ,intake gasket , or carb gasket
or poor gas flow out of the tank /filter /screen B:-) Dnoym Edited by Dnoym N. S. Can. - 15 Nov 2016 at 6:28pm |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8461 |
Posted: 15 Nov 2016 at 6:29pm |
My G used to surge. A 2nd governor spring fixed it. It's not a big spring, a small one about as big around as a pencil, and a couple inches long. It doesn't take much tension to pull it, but it worked!
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 998 |
Posted: 15 Nov 2016 at 6:44pm |
Do you have generous flow out of the bottom of the carb if you pull the plug. On my WD I had restriction in fuel shut off above the glass cup. Once all cleaned...back to full power.
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 15 Nov 2016 at 9:37pm |
If you have to pull the choke out to keep it running good, you are starving for fuel. Need to check fuel flow to and through the carb. Remove the plug or the main needle valve from the bottom of the carb and check fuel flow there. Let the fuel run for several minutes and see if it maintains a constant flow. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
