WD45 met it's match |
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2043 |
Topic: WD45 met it's matchPosted: 22 May 2017 at 8:30pm |
Got one in the shop with a broken crankshaft. Broke between number one main and number one rod.
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Posted: 22 May 2017 at 8:36pm |
Whew! Is there a story about how this happened?
WC, CA, D14, WD45
MACK
Posted: 22 May 2017 at 9:05pm |
Crank has been reground with out a radius ground in?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8758 |
Posted: 22 May 2017 at 10:19pm |
In the arm? My 45 cracked in front main near rear edge.Grinder said that's where most crack.Too much timing can hurry this along.That knock you hear when pulled too low too hard....
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 23 May 2017 at 9:19am |
What were you doing that you weren't supposed to be......... I wanna hear the story also Lon!
Lon(MN)
Posted: 25 May 2017 at 5:15am |
It's a customer tractor. Was using it with a nine blade mower. He had it at a show years ago and it was tested at 54 hp.
The crank had the radius. Going to detune the engine a little as it is going to the field again.
