WD45 lifter arm hold valve
twinsonfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Topic: WD45 lifter arm hold valve
    Posted: 22 Nov 2020 at 9:53pm
Does any one happen to know the size o rings for the lifter arm hold valve on the WD45.  part number 70223580 ?  Agco replaces that parts number with 70925488 which is not even close to the correct size o ring....
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2020 at 12:57pm
Anyone?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2020 at 1:00pm
You got it from an AGCO dealer, right???    Call them and express your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2020 at 3:05pm
I did.  AC Mccarthy out of Durand, IL.  They said they were going to research the spec for the part number, that was a few days ago.  I don't think a $1.10 o-ring is going to be high on their priority list.  But who knows...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2020 at 3:31pm
But, my point is the Oring you got is mismarked or their subbing up to a different number isn't correct. AGCO needs to know about it so they can correct it.  This info has to come from the Dealer.
Edited by DrAllis - 23 Nov 2020 at 3:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2020 at 4:04pm
The parts guy told me that 70223580 sub to 70925488.  I told him that the 488 part number does not match the 580 part number in the parts book.  He knows that...
