WD45 Hydro lift arm help
twinson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Hydro lift arm help
    Posted: 17 Aug 2022 at 9:22am
I have a WD45 set up to pull a Woods rotary chopper.  I am having a problem with the vert position floating up or down as I mow.  The level of the woods cutter does not stay in the place I set the lever.  It seems there is a very narrow position in the middle of the quadrant lever where the levers don't move.  But they will creep up or down over time.  What adjustments might I need to make to the lower right hydro regulator on top of the pump.  There is a screw on the end and them there looks to be a wheel lock device on the rear.  That rear device is not unlocked.  Thank you
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2022 at 9:46am
A quick & dirty remedy if you don't want to fight the hydraulic system.  Get some (they go by different names) stroke limiters, depth stop collars that just snap over the cylinder rod.  They come in various thicknesses.  You can't obviously adjust on the fly, but you can raise the mower normally.  I wouldn't have even known about them but my 45 with a Woods mower had them from previous owner.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2022 at 10:12am
I don't think you will ever to get the arms on a WD45 to stay put in a selected position. At least I never could.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2022 at 10:24am
If the hydraulic pump and hold valve are in good condition AND ADJUSTED CORRECTLY, they will hold a load just fine.  Pump must be set for "HOLD" position configuration. The hand lever should "click" (detent) somewhere near the center of the quadrant. If it does this and the pump still continues to raise (even slowly raise) the linkage is out of adjustment. In the hold position, the pump should be shut off and oil is trapped in the right lift ram so it cannot lower..
BMinor0788 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BMinor0788 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2022 at 8:26pm
I had some lifting issues with my WD-45 when I swapped the pump out for a newer one with good linkages. I had to readjust the linkage for the quadrant control and I can hold a load all day long wherever I set it.
Also, if you’re lifting and holding heavy loads, make sure you switch your left lift hose to the other hold side on the valve. This will equalize the hold on the cylinders. My Oxnard blade book states this and it’s how I have mine since I don’t have the rear remote and I don’t need Delayed Lift functionality.
Brandon
Edited by BMinor0788 - 17 Aug 2022 at 8:30pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2022 at 9:13pm
Is  this pull type with hydraulic cylinder or mounted? Pull on draw bar cam make it lift or lower if linkage is miss adjusted or worn.                    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2022 at 9:19pm
Mounted the a three point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2022 at 9:20pm
What does the wheel lock do at the back of the hyro flow valve on top of the pump?  Or the front screw on the flow valve?
Edited by twinson - 17 Aug 2022 at 9:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2022 at 6:16am
Screw located on the hold valve that locks the plates together should have the plates locked together. Front screw on the hold valve should be screwed OUT.  Lower screw on the traction booster linkage should be screwed in locking the lever so it cannot move. ALL of this is in your owners manual and on the decal on the side of the battery box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2022 at 7:20am
Thank you. I have no manual or sticker on battery box.  Grandpa's old tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2022 at 4:27pm
What is the diameter of the rams in the lift arm of the WD45?  ( I am not near the tractor at the moment)  What are those limiter clamps actually called that you clamp on the arm to prevent the ram from fully lowering?  Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2022 at 6:49pm
Cylinder stops
This page was generated in 0.270 seconds.
