WD45 Hydraulics and Steering |
Runamuck ![]() Bronze Level ![]() Joined: 22 Oct 2014 Location: West Central Mn Points: 31 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Nov 2017 at 7:22pm |
Have a tractor in the shop that needs leaks fixed on the hydraulic pump and valve. Ordered a bunch of other parts from Steiner, but don't see any of this in the catalog. Where can I find seals, o-rings, etc to fix these leaks, and a gasket for between pto gearbox and trans? I also have to put on pwr steering he took off another tractor. Anything special I need to know? Thanks.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7522 |
Your local AGCO dealer should have those items.
Albert ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: NW MO Points: 410 |
I can help you with the pump gaskets o rings and seals but would recommend you replace the balls and springs also. we also have the pto gasket. 660-582-5150
Albert |
