WD-45 Hydraulic Pump
matt5569 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matt5569 Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Hydraulic Pump
    Posted: 28 Aug 2010 at 9:03pm
My WD-45 is starting to leak quite a bit from the seals on the control box on the back side of the hydraulic pump.  Leaks right at the seals where the linkages go in.  I was hoping someone could tell me if it's fairly easy to get the seals and to replace them.  I've never messed with the pump/control before, don't want to mess it up anymore than it already is, but I'm getting tired of buying hydraulic fluid!  Thanks, Matt
Edited by matt5569 - 28 Aug 2010 at 9:06pm
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 9:06pm
You should be able to re-seal that pump easily, parts are available.
