WD45 Hydraulic Hold Position |
jyanna ![]() Bronze Level ![]() Joined: 31 Oct 2010 Location: Michigan Points: 29 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Mar 2012 at 8:51pm |
Been searching posts about hydraulic hold positions and now I am more confused. I have a 3 pt on my wd45. I cannot hold it at one position. It wants to drift up or down. Can I fix this?
Thanks!
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
WILL WORK IF PUMP IS SET CORRECT RECHECK SETTING HAD IT HAPPEN ON A COMBINE ONCE LOWERSCREW ON PUMP WAS NOT SCREWD INTO PUMP BODY
FRON AN A-C MAN DRAWBAR CONTROL ARM ACTIVATE IT WHEN PULLING UNIT
Chris (swIA) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Prescott, IA Points: 319 |
Set the hydrualic control lever at the hold position with a load on the arms and shut the tractor off. If the arms stay in place, the linkage needs adjusted. If they still go down it's time for a new ball and seat in the hold position valve. This assumes that the pump is set to hold like Norm said.
