WD45 hydraulic fluid leak at outlet
Bob (mo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob (mo) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 hydraulic fluid leak at outlet
    Posted: 22 Mar 2020 at 12:45pm
On my 1955 WD45 rear hydraulic remote that box with the adjustment knob which I think is called transport valve blows fluid out both sides when the lift arms max out at the top. Whats went bad in there and how do you go about fixing it? Any info anybody can give will be much appreciated.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 8:58pm
Gaskets and orings. I would check pressure.     MACK
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 9:11pm
I had that problem to many years ago.  As said above requires an O ring or seal.  Check with Sandy Lake - they are a sponsor on this site - they may well have the parts you need.
Good Luck!
Bill Long
This page was generated in 0.081 seconds.
