WD-45 gear shift knob removal |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2685 |
Topic: WD-45 gear shift knob removalPosted: 15 Jul 2019 at 12:14pm |
Hope this isn't to dumb but I need to replace the shifter boot. How do you remove the shifter knob?
Hockeyman
Posted: 15 Jul 2019 at 12:33pm |
If you can't get the knob off easily, you can always remove the whole shifter... slide the boot on from the bottom up.
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 15 Jul 2019 at 2:33pm |
Knob is threaded, tends to seize on there good may need a strap wrench or something to break it loose. A pipe wrench also works but will chew it up good, it is just hard plastic. They aren't that expensive if it's old might want to replace it also.
mdm1
Posted: 15 Jul 2019 at 3:42pm |
I will try the strap wrench. Now I just have to remember where I put the new boot!
Posted: 15 Jul 2019 at 4:03pm |
A true WD-45 has a rubber knob that you just twist it and pull off. If you have a threaded on plastic knob, you either have an old WD or some customized gearshift lever.
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2079 |
Posted: 15 Jul 2019 at 4:04pm |
The knob on a WD 45 is not threaded on. It is a hard rubber that is forced over the steel knob that is on the end of the shifting lever. Just have to fight it over the steel knob. Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
Posted: 15 Jul 2019 at 4:05pm |
The good Doctor was faster than me. Den
mdm1
Posted: 15 Jul 2019 at 4:10pm |
I have no doubt that it is a WD-45. I didn't think it was threaded but really didn't know. I guess we will fight with it. Thanks for all the replies.
TimNearFortWorth
Posted: 15 Jul 2019 at 6:33pm |
I have a set of picks that have good stout handles, straight, curved and a 90 in the set. Have used the pick with the 90 to remove D-Series shifter knobs so I can replace the dust cover boot as the available boots just don't seem to last.
I break the rubber knob free so it rotates, then start working the 90 degree pick under it while working your way all around it while pulling up at the same time. Don't give up as it'll come and the 90 pick is also good for working the replacement boot on. Throwing the new boot in a pan of boiling water for a couple minutes helps soften it and a few drops of dish soap atop the shifter handle "ball" makes it easier to get them on.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 16 Jul 2019 at 9:17pm |
Mike, I take a small hypodermic and squirt Dawn dish soap UP into the knob after getting it to turn freely. They can be a bear, but they just pull up and off.
