WD45 front pedestal bearing and race
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 front pedestal bearing and race
    Posted: 07 Jun 2021 at 7:38pm
Going through the front pedestal on my brothers WD45 and got it all apart except for getting the old race out. Front pedestal is still on the tractor and really don’t want to remove it if we don’t have to. How do you get that race out?
ryan
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2021 at 8:31pm
Weld on the race a couple spots. It should shrink the race so that you can get it out.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2021 at 10:30pm
Ryan, I re did the front pedistal on dads WD 45 several years ago. One of the bearings has a curved race with barrel shaped bearings. I could still get the bearing from AC. Because of the cost, I chose to get it from O'Reillys, big mistake, I was promised the bearing overnight from O'Reillys. It took 3 weeks to get it. I pulled the pedestal, it was fairly simple to work on with it out. I took the right side frame rail loose, cribbed up the tractor under the hand clutch part of the tractor. If I remember correctly the seals were only available from AC. Good luck with your project. I also put new u joints in the steering shaft and replaced all the grease zerks. It steered a whole lot easier.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2021 at 6:32am
I made a long punch and drove out the race from the top.
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2021 at 6:53am
X2 - I did the same.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2021 at 8:01pm
I used a hammer and a 3' or so length of 1" round stock I had laying around to knock that race out. Mine wasn't stuck in there too badly.
When I ordered a replacement bearing from AGCO about a year ago, the cone and race they provided were just plain old tapered roller bearings, not the barrel/spherical/whatever you want to call it style that was in there and completely shot.
From looking at the parts book, early WDs had a different part number for the bearing and race, so I almost wonder if AC started with a plain tapered roller bearing and then had to change to the barrel style later in prouduction due to some problem with the tapered roller bearings not holding up. I looked and looked and as I recall you can still find the barrel style, but they are pricey ($200+). I think AGCO's logic is the tapered roller bearing will probably last most tractors for the rest of their lives, and they're probably right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2021 at 8:47pm
We ended up pulling the shaft out to do it. Not as bad as we thought it would be to do.
We got the bearing and race through AGCO.
New question. How tight does the bottom bolt need to be? We tightened it to what we thought was good but I wanted to know from you guys how tight it should be.
Edited by ryan(IN) - 08 Jun 2021 at 8:49pm
ryan
