WD45 front bucket hydraulic dump
Offfishn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Offfishn Quote  Post ReplyReply Direct Link To This Post Topic: WD45 front bucket hydraulic dump
    Posted: 22 Mar 2015 at 5:09pm
Anyone got some pics of one of these?
The gravity pin is such a pain in the a%$.
ed
Edited by Offfishn - 22 Mar 2015 at 5:09pm
54' WD45#160414 w/AC loader, 60" mower, sickle & 72" back blade.
In Michigan, out annoying the neighbors in something that has a motor in it!
Rltool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2015 at 7:12pm
Not sure what your looking for Ed. What kind or model of loader ? Not sure what you mean by gravity pin? Any pics?
Ray W.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2015 at 10:01pm
He's referring to the latchpin setup of a trip-bucket loader system. To operate the bucket, you set the bucket on the ground and back up, which rolls the bucket to a horizontal position, where a ramped-pin latch locks into the bucket. Stab it into a manure pile, lift up, get it over the spreader, and pull a chain connected to the pin, which releases the bucket, it spins, dumping load. Repeat.
The geometry of the trip-bucket doesn't lend extremely well to being made totally hydraulic, because the bucket's pivot shape is 'wierd' compared to a square bucket, but it can, and has been done many different ways. IMO the best 'method' is to use the double-acting ram centered between the arms, operating a 'hairpin' type double-lever arrangement. The problem, however, is that the trip bucket requires LOTS of reinforcement in order to remain rigid under hydraulic forces, and the lift arms usually need same to withstand the added leverage and weight. most trip-bucket loaders weren't really all that 'strong'... just stronger than a farmer with a poop-scoop...
