WD45 frame separation question
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 frame separation question
    Posted: 28 Mar 2011 at 7:12pm
I Am debating on pulling the frame from the tractor. Can this be done without removing the engine, clutch housing etc from the rear differential? I have a tractor dolly built for this sort of thing and would support the frame on jack stands. I need to get into the inside of the frame with the putty knife to get at the grease. It also seems like it'd be easier to paint that way.
If possible, I'd like to undo the four bolts that hold the frame to the fly wheel housing, and the four bolts at the rear, and then just roll the tractor away from the frame.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
JohnThomas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 7:19pm
That's a lot of work to clean out the channels WC... I made a bent tube up in a J and squashed the end a little ..fastened to my power washer and clean them right up. Make sure you put goggle's on tho!!!!  :<)
I first soaked them in that Purple Cleaner from the auto supply store here...as I did most of the engine.
Life is short...Make haste to be kind
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 7:22pm
You can do that, only just remove one frame rail at a time and clean the inside and paint then re-instsall and do the other side.  Toughest part will probably be getting the front pedestal bolts out as they are often well rusted in place.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 7:22pm
I read on hear you take one off at a time.
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 7:47pm
I am debating doing the same thing on my WD45. I have asked this before. Do one side at a time and support the drive line under the clutch housing. With that plus the opposide side still in place, others have said this works well. I am interested in hearing more adivce too.
Jeff
1954 WD45 NF "Iron Tater"
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 7:52pm
OK. Sounds good. Those pedestal bolts where recently removed last fall so I could put a chain bar on. They all came loose with my breaker and a cheater pipe. Power washer is not an option. everything has been cleaned up and prepped for primer and there is just two much bare metal to involve water.
German Shepherd dad
#WD234847
#WD88193
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 8:04pm
If you don't plan on moving it, don't worry about supporting anything, as long as you leave one side on and tight.  If you are concerned about stressing something, throw a jack stand or floor jack under the bell housing.  I did my 45 the same way, one frame at a time, with no supports, but don't start it or move it, and you will be fine.
Still in use:
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 8:32pm
I just did my wc a couple months ago. I put blocks under the clutch housing and under the front of the engine. I left the angle iron front mount bolted to the engine with blocks under it sideways so the engine couldn't roll on it's side. The pic shows one frame rail left on one side but I pulled it off later without putting the other back on.
Edited by Thad in AR. - 28 Mar 2011 at 8:35pm
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 9:01pm
BTDT
This page was generated in 0.077 seconds.
