WD45 flywheel
Lew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lew Quote  Post ReplyReply Direct Link To This Post Topic: WD45 flywheel
    Posted: 21 Sep 2022 at 10:01am
Upon tear down of my WD45 for refurbishment I found the bell housing seal 70224687 leaking causing the clutch area saturated. Inspecting the flywheel I found heat cracks that were all the way through the inside lip of the flywheel. My question, is this a major issue since the flywheel is solid about 1/2" back from the inside lip; I am going to have it resurfaced and the clutch disk contact is not close to this area. The tractor will be retired from farm work and used as a masterpiece of an aera gone by.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 4:07pm
It's possible the retired tractor will go back into service if you sell it someday. Maybe repair the problem while you have everything apart?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 7:26pm
I would replace the flywheel since you are already in there.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 9:18pm
Never saw one that didn't have heat cracks that had Ben used.                     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 8:43am
What MACK says
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2022 at 6:57am
If they're just hairline cracks, most will have those and just resurface it and use it...if real deep and opened up cracks, then replace it, if you think you need to...
This page was generated in 0.176 seconds.
