WD45 flywheel |
Lew
Joined: 09 Jun 2017 Location: Buford, GA Points: 59 |
Topic: WD45 flywheelPosted: 21 Sep 2022 at 10:01am |
Upon tear down of my WD45 for refurbishment I found the bell housing seal 70224687 leaking causing the clutch area saturated. Inspecting the flywheel I found heat cracks that were all the way through the inside lip of the flywheel. My question, is this a major issue since the flywheel is solid about 1/2" back from the inside lip; I am going to have it resurfaced and the clutch disk contact is not close to this area. The tractor will be retired from farm work and used as a masterpiece of an aera gone by.
jvin248
Posted: 21 Sep 2022 at 4:07pm |
. It's possible the retired tractor will go back into service if you sell it someday. Maybe repair the problem while you have everything apart? .
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 21 Sep 2022 at 7:26pm |
I would replace the flywheel since you are already in there.
MACK
Posted: 21 Sep 2022 at 9:18pm |
Never saw one that didn't have heat cracks that had Ben used. MACK
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8987 |
Posted: 23 Sep 2022 at 8:43am |
What MACK says
Rick
Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3695 |
Posted: 24 Sep 2022 at 6:57am |
If they're just hairline cracks, most will have those and just resurface it and use it...if real deep and opened up cracks, then replace it, if you think you need to...
