WD45 final drive |
WhiskeySup
Topic: WD45 final drivePosted: 06 Jun 2011 at 1:14pm |
Is it normal to hear the final drives while driving. Mine makes a low growl sound. Have plenty of oil in the trans.
Brian G. NY
Posted: 06 Jun 2011 at 6:34pm |
The "final" drives are the big bull gears powered by the pinion gears off the differential ouput shafts.
So.........you may want to pull the plugs on the final drive pans to see if they are full.
A certain amount of whine/howl is normal; especially on a tractor that has been really worked over the years.
RickUP
Posted: 06 Jun 2011 at 7:02pm |
I bought a '53 wd-45, and changed all the fluids, and found no metal shaving. There is a gear noise everytime I work it. I'm not worried about it. If you hear growl and grinding then check fluids for metal. You don't have to drain all of it to check. Good luck.
AC WD45
Joined: 28 Sep 2009 Location: Mid Michigan Points: 2078 |
Posted: 06 Jun 2011 at 8:10pm |
Yes, when I work mine hard I can hear a gear whine to. Guy who used to work where the tractor was bought said they did that even when new.
German Shepherd dad
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3953 |
Posted: 06 Jun 2011 at 9:05pm |
My WD 'sings' pretty well, too. It has not gotten any worse in the ten years that I have had it. It seems quietest in 4th, which it doesn't get into very often, only when goin' for the mail!.
79fordblake
Joined: 01 Jul 2010 Location: West Kentucky Points: 829 |
Posted: 06 Jun 2011 at 9:45pm |
My WD45 also does it, it is full of oil and there is no metal shavings.
John In.
Joined: 20 Sep 2009 Location: New haven In. Points: 69 |
Posted: 07 Jun 2011 at 1:17am |
My does it once in awhile. mostly when just driving it down the road..it comes and goes..
WhiskeySup
Posted: 07 Jun 2011 at 8:43am |
Many thanks for the feedback-puts my worrys to rest. This is my first tractor and with a limeted budget I cant afford major repairs.
