WD45 distributor trouble |
dallypost ![]() Bronze Level ![]() Joined: 19 Apr 2012 Location: Idaho Points: 11 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Apr 2012 at 9:45pm |
I have a WD45 that has completely discharges the battery after just a few hours of use. This tractor was converted to a 12 volt system and now has an ignition switch. In probing the system, I noticed that the ignition and accessory terminals all short directly to ground when the key is in the run position. I disconnected one component at a time until the short disappeared. What I found is that the coil terminal on the distributor is shorted directly to ground. So now I am wondering, can this distributor be rebuilt or is there a source where I can buy one.
Thanks in advance. |
Why does the distributor need to be rebuilt? MACK
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7515 |
The problem has nothing to do with your distributor.
Ian ![]() Silver Level ![]() ![]() Joined: 28 Aug 2011 Location: Carroll, Ohio Points: 86 |
What they are saying is the distributor is internally grounded, that's normal. If it is discharging the battery while running it is not charging properly. did you test the voltage at the battery with it off and with it running?
1980 AC 616
1958 AC D14 1960 AC D14 1987 Cub 1204 1982 Cub 682 1974 Cub 154 Lo-Boy (SOLD) Hauler: 1998 Dodge Ram2500 Cummins |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12009 |
Coil or the Ignition switch could be the culprit!
Steve@B&B |
The coil terminal on the dist would always be shorted to ground when the points are closed. Sounds like your alt isn't working. Put a volt meter across the battery with the engine running at half throttle or more and see what it reads. Should be about 14 volts. The distributor is not your problem. Open the points and your dead short to ground will go away.
