WD45 Diesel |
Post Reply |
Steve allis dozer
Silver Level Access Joined: 10 Apr 2011 Location: Australia Points: 232 |
Posted: 19 May 2016 at 8:10pm |
Hi does anyone know where i can buy a bottom radiator hose for a wd 45 diesel I have a fiat allis m65 grader and i bought a new radiator for it , I looked around and the WD seamed to be a close match I ordered it from the USA and I was right it bolts straight in , now i need a bottom hose its 11/2 to 13/4 with a right angle bend . any help will be much appreciated
Thanks Steve
Steve allis dozer
Larry in NC
Orange Level Joined: 09 Feb 2016 Location: NC Points: 1041 |
The WD45D bottom hose is straight and the same as the WD and WD45. Part #70227176
TedBuiskerN.IL.
Orange Level Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
There is actually a metal tube with the proper bend attached by two straight short hoses at each end.
Don(MO)
Orange Level Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Here's a shot of the tube.
dawntreader74
Orange Level Joined: 28 Oct 2013 Location: Manteno Points: 1761 |
i cut one down for a chevy truck small block motor' had just the right bend to it
LeonR2013
Orange Level Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
muffler shop can bend one for you. Leon R CMo
Don(MO)
Here's a shot of the lower hose, like said above it's a straight hose.
Steve allis dozer
Steve allis dozer
That all makes sense now Thanks fella's , maybe i could try a D19 bottom hose
Don(MO)
Looks like you have a D-262 like the D17's used, the D19 had two diff water pumps low and high mount pumps. It might save time and just use flex hose. |
Rick
Orange Level Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3642 |
I think the D19 lower radiator hose looks like a good match. Rick
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33680 |
Sure looks like a D19 engine with the injectors and the fuel filter housing.. but no turbo... Last of the D17 had the water pump like shown in the pic, otherwise there would have been a water volute coming out of the head on the left side front corner on the earlier engines.
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3747 |
Looks like the lower hose for a 230 gas out of an AII gleaner would fit that. Can't see the rad outlet very well but it looks just like mine
Post Reply | |
