Wd45 diesel generator repair |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1145 |
Topic: Wd45 diesel generator repairPosted: 14 Nov 2025 at 6:07pm |
Good evening!!
Is there a source for the original 12volt generator parts? I notice the brushes are very well worn and it’s not charging very good. I’d prefer to leave it original with the power steering pump on the back of it if it’s possible. Thanks |
Phil48ACWC
Posted: 23 hours 50 minutes ago at 5:09am |
Most likely it is a Delco Generator and same as from a '50's to early '60's Chevy generator. Take yours apart to confirm, click on below, scroll down, and take your pick:
Edited by Phil48ACWC - 15 hours 34 minutes ago at 1:25pm |
Alvin M
Posted: 22 hours 10 minutes ago at 6:49am |
AGCO Has Them Part # 70231998
Edited by Alvin M - 22 hours 9 minutes ago at 6:50am |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7547 |
Posted: 21 hours 10 minutes ago at 7:49am |
A local starter/alternator repair shop can make it as good as new.
55allis
Posted: 5 hours 7 minutes ago at 11:52pm |
When I’m done using the tractor I will slip it apart and confirm what it needs, only want to pull it apart once.
What involved in resealing the power steering pump on the back of the generator? It seeps enough to make a mess of the generator parts. Got an itch to get the leaks sealed and the charging/wiring working properly. Thanks |
