WD Plow hook up |
   PatrickBeth
   Joined: 04 Oct 2015 Location: Wisconsin Points: 184  |
      Quote   Reply
     Topic: WD Plow hook upPosted: 10 Aug 2016 at 12:49pm  |
   Friday going to see a two bottom plow for my WD.  Does all snap couple plows work on a WD?  I know the CA s used them too... Anything I should be looking out for so I don't buy a plow that is too small?  Thanks
      Quote   Reply
     Posted: 10 Aug 2016 at 1:03pm |
   I've hooked up to the snap-coupler eye on the plow with the regular drawbar clevis and a bolt. You do not need the snap-coupler bell on the tractor. It isn't easy, but it can be done.
   CTuckerNWIL
   Joined: 11 Sep 2009 Location: NW Illinois Points: 22825  |
      Quote   Reply
     Posted: 10 Aug 2016 at 1:09pm |
   Dr., in my eye, I see his WD as converted to SC already? I think his question is about length of the plow drawbar and width of the lift links.
  Lena 1935 WC12xxx, Willie 1951 CA6xx Dad bought new, 1954WD45 PS, 1960 D17 NF  |
   PatrickBeth
      Quote   Reply
     Posted: 10 Aug 2016 at 1:14pm |
   Converted to snap coupler...  need to know if any plow will work, just in case a CA snap coupler plow is too small.  All I know about this two bottom plow has a snap hitch, but whether or not it will work on a WD if it was meant for a CA...
   wfmurray
   Joined: 13 Sep 2009 Location: Bostic NC Points: 1225  |
      Quote   Reply
     Posted: 10 Aug 2016 at 3:03pm |
     Beam for a five tooth ripper was to short for a D/14.
   Dakota Dave
      Quote   Reply
     Posted: 10 Aug 2016 at 6:47pm |
   Measure the width of the lift links. If it's the same as your WD it'll work if it's about 6" narrower it's for a CA. The plows with two sets of hole on the lift bar can be used on either. The length should be the same. I've mover the Three point adapter from a CA to a Wd45 length wise they were the same.
   PatrickBeth
      Quote   Reply
     Posted: 10 Aug 2016 at 7:02pm |
   Thanks Dakoda, that will give me what I'm looking for.
   PaulB
   Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5163  |
      Quote   Reply
     Posted: 11 Aug 2016 at 5:49am |
    A CA plow will have a shorter drawbar that what would be usable on a WD. The lift links are not stationary so they won't be a problem.  A WD/WD45 drawbar could be put into a CA52 plow or you could find a "long" eye to bolt to the CA drawbar on the plow.
  Real pullers don't have speed limits. If you can't make it GO... make it SHINY  |
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
