WD OR WD45?
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Topic: WD OR WD45?
    Posted: 06 Aug 2012 at 5:13pm
Is this a wd or wd45?
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 5:15pm
WD pre mid-51 with a distributor changeover.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 5:15pm
I see a 201 engine in there, so it's a WD.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 5:16pm
Need tractor serial number.
See picture for locaton.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 5:17pm
Gees you guys are fastLOL
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 5:17pm
Motor is a 201 block which would make it a WD but alot of changes could have happened in 60 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 5:31pm
What s it worth?  Tire are fair, motor is free. He said it ran when he parked it
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 5:50pm
Limited pictures, but what can be seen looks ok.  WFE, tin work that can be seen looks ok.  offer $800, you can part it if you don't want it.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 6:06pm
It has an updated charging system with the voltage reg on the battery box. Might that be a 12 volt genny?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 6:07pm
Yes its 12v.
