WD oil pan gasket installation |
Don(MI) ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: Michigan Points: 3887 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Jan 2011 at 6:53pm |
Just a quick question...
When installing the new gasket set for the oil pan on a WD.. Whats the normal length you guys leave the thick gasket on both ends (front and rear mains) above the height of the side gaskets? About a 1/4" or 1/8"? What do I need to do to make sure I got a good tight seal around the mains?
Thanks!
allisorange ![]() Silver Level ![]() ![]() Joined: 27 Mar 2010 Location: perkins, michig Points: 381 |
Don't cut anything off or you will have a leak. Others will post soon and they will tell you not to cut them off. John Carlson |
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
do not cut any off of them or you will have problems leaking!! have seen it happen
redline ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Collins, IA Points: 1013 |
What a timely question! With a little luck, I too will be installing a pan gasket soon. I am glad I read this, I might have done some trimming that I would have regretted later.
I sure do like this website, and I sure appreciate the knowledge that is shared here!
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Don, Please don't cut them off, the guys are spot on about this!! Get a old soup can and clean it up then roll the end gaskets inside the soup can and leave them there for two or three days, the end gaskets will fit the pan and retain there shape from the can, use the little clips to hold the ends in place and don't use a lot of sealer on them.
hope this helps. Here's the can I use.
Don(MO)
![]() Edited by Don(MO) - 17 Jan 2011 at 7:31pm |
piece of 4" PVC PIPE WORKS GOOD ALSO FOR OVERNITE CLAMPING
Whadda ya use the salt for? Edited by redline - 17 Jan 2011 at 8:00pm |
dannyraddatz ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Plainfield, Ill Points: 848 |
Some kits come with small clips to hold the front and rear gasket during installation. The A.C part number is 70229177 and when I did mine last summer it was a big help. Don and other members are right on about the can trick for getting those gaskets to work.
Danny
P.S. I agree don't cut anything.
Danny Raddatz
Thanks guys!
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
for those interested the NAPA number is FPG OS30130C (Fel-Pro brand), which also includes the clips
Allis Wd45 ![]() Bronze Level ![]() Joined: 06 Nov 2017 Location: Washington Points: 171 |
Bill, I know this forum is 8 years old now but are the Napa gaskets as good as agco or elsewhere? I’m doing the pan gasket on my wd45 now.
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3042 |
If still available, Felpro's are always good gaskets.
Will the NAPA Felpro kit work on a wd45 too?
Yep, still available. WD45 is same pan and gasket.
jboettcher ![]() Bronze Level ![]() ![]() Joined: 25 Sep 2017 Location: wisc Points: 27 |
It appears FelPro makes a 1-piece neoprene gasket for a WD.
![]() ![]() Does anyone know anything about this item? |
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2677 |
Go to the farm equipment-knowledge base forum. There is an excellent post on exactly how to do it!
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2571 |
Anyone ever try one of those one piece gaskets? Looks interesting. AaronSEIA
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4072 |
Put one in a big block Chevy three or four years ago. So far so good. I did this in chassis so a four piece set would have been a nightmare. No experience with the WD set.
Update. I fixed a leaking oil pan on my WD without a gasket. I used Right Stuff from Permatex.
I went to a engine machine shop and told them what I was doing, and they suggested Right Stuff. It’s very heavy bodied and you need to work quick. I let it set up overnight and I’ve run in an hour so far with no drips. (And I wasn’t chasing 4 pieces of cork around) Just a heads up, it makes life easy |
