WD Hydraulic problem |
LaJaMe ![]() Bronze Level ![]() Joined: 14 Sep 2014 Location: wisconsin Points: 172 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Jul 2015 at 11:59pm |
I could use some thoughts from anyone. When I hook up equipment to my auxiliary connector on the rear, there is pressure on the hose but no lifting. Could this just be the wrong ram, on the mower, for the 45 system? Have tried different settings on the pump but no change. Any thoughts?
truckerfarmer ![]() Orange Level Access ![]() ![]() Joined: 26 Jan 2013 Location: Watertown, SD Points: 3284 |
Are the cylinders on the equipment you are hooking to set up for single action or double action? Are there 1 or 2 hoses on the cylinder? The WD was designed to run single acting cylinders (one hose). If the cylinder has 2 hoses on it, remove the hose that is not being used and put a cylinder exhaust port in.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
Coupler bad if it has pressure on hose before coupler. If pressure after couppler, the hose could be plugged. MACK
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21914 |
Your tractors lift arms should go up and down as you raise and lower the hydraulic lever. If they work, you must have bad or mis-matched coupler parts. If the lift arms don't do anything, you have hydraulic pump problems.
