WD greasing front wheel bearings
G226WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote G226WD Quote  Post ReplyReply Direct Link To This Post Topic: WD greasing front wheel bearings
    Posted: 06 Jul 2011 at 3:20pm
How do i remove the front wheel bearings to repack them?
I took a look at it and it looks like a big cap with a hex head but im not sure if it threads out or not.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 3:24pm
Yup, the caps are threaded.
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 3:30pm
  The caps are threaded on, you will have to use a pipe wrench to get them off.  After that the wheel bearings are like any other normal wheel bearings.  There should be a grease/dust seal on the back side, originally they were felt.  Be  sure to use a little anti-seize on the caps when you reinstall them.
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2011 at 8:38am
Fill cap full take out just enough to get back on and it pushs grease into the bearings repete until it come out the inside. You can also drill and tap for a grease fitting, into the the cap. I used a rag over the better caps, to keep the pipe wrench from messing them all up.
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
