WD Differential Leak
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Topic: WD Differential Leak
    Posted: 03 Jul 2012 at 11:20am
I have a 51 WD that I put back together about 10 yrs ago, it had spent the previous 25 yrs in my uncles barn without moving. It has always leaked a little gear lube, but in the last year, the amount seems to be increasing. I've intalled new gaskets on the sheet metal plate under the trans itself, the rear cover,and the PTO to the trans gasket. Also Teflon taped the threads on the drain plugs. Cleaned it up and still have a drip from somewhere above the snap coupler, as it gradually drains off the bell. Doesn't seem to be coming from the PTO box, although disassymbling and replacing the oil seals in PTO itself is probably my next move. Any suggestions, comments or gaskets I missed?
GT in Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT in Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 12:07pm
Could be just marking it's territory...
g
1955 WD45 we like to call Ruby
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 4:17pm
I have a leak in mine around the hand clutch shaft, runs down and is hard to tell where it is coming from but think I narrowed it down to that shaft.
bryan/silex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan/silex Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 4:34pm
I believe the housing splits just ahead of the snap coupler mount, which means alot of disassembly to fix
