WD cultivators
JCSinPITTS,PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Topic: WD cultivators
    Posted: 29 Sep 2012 at 7:55pm
Was looking over Dads wd 2 row cultivator tractor and noticed the DRIVER side is missing and last tooth on the inside?@!?@  The pipe is just cut off???  there are 3 tines and then the corn row and then 2 tines on the driver side. on the pass side there are 3 tines the corn row and then 3 more tines. is this factory of did someone cut off in the pass and why???
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 1:58am
If you are talking about the right side of the tractor then there is only 2 tines, since you mentioned "tubes" sounds like you have a  WD-10 series cultivator. You will also see when looking at the third tine on the left inside (rear one) it is right under center of tractor. HTH John
been there done that, not doing it again...
