WD Belt Pulley
boilerpete View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote boilerpete Quote  Post ReplyReply Direct Link To This Post Topic: WD Belt Pulley
    Posted: 04 Jul 2015 at 9:34am
On my 1953 WD, I've not had a belt pulley in it for years.  I recently acquired one, but when I put it in and fired it up, it leaked oil out the side through the opening in the frame rail.  Is there some sort of seal that goes on the belt pulley to keep it from leaking?  Is it the same setup on a WC?  How does that seal get installed?
Thanks!
Ashaman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ashaman Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2015 at 10:25am
In for info as well, I'd like to get mine operational (even though I have nothing to use it on). It's RTV'd around the tube right now, but the cutaway diagram I found shows a seal inside.
- Brian
'54 WD (wife's grandfather's - resto?)
'50 WD (new workhorse - gets used!)
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2015 at 11:24am
There is a cork seal between the housing and the frame. If it was all dried out the cork broke when you pulled out the plug. you can see it if you pull the shaft back out of the hole and look inside the frame. you have to loosen the frame rail to put a new one in.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2015 at 11:32am
Not sure but it seems like I heard that you can tighten the 3 cab screws on the frame near the pulley hole, worth a try.
Dusty
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2015 at 1:53pm
Directly from the service manual.
Adjusting the gear lash is apparently an important aspect of the installation.
