Wd 45 rear section in a wd frame and engine |
blue924.9
Joined: 22 Mar 2013 Location: George Iowa Points: 1089 |
Topic: Wd 45 rear section in a wd frame and enginePosted: 06 Sep 2019 at 10:16pm |
Found a wd 45 rear end and transmission online for my wd. I could use it since my transmission is noisy and the 45 combo has a lower first gear
I am wondering if the 45 transmission and rear end will bolt to my frame engine and final drives? |
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 06 Sep 2019 at 10:49pm |
Dan,
Seems like that should work fine. Good luck with your rebuild. Regards, Chris
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 07 Sep 2019 at 7:55am |
The last 20,000 or so WD's were built with that rear section and curved gear shift.
Should be a bolt in
MACK
Posted: 07 Sep 2019 at 10:05pm |
Make sure it don't jump out of gear. MACK
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 08 Sep 2019 at 9:42am |
Our '53 WD had the curved shifter stick like the WD-45. The tires were smaller than the '45. I don't know if the wheels were the same. If I remember right the WD's were 12" and the '45 were 13".
Dusty
