WD 45 next? YES!!! |
Page <1 3031323334 45> |
garden_guy ![]() Orange Level ![]() Joined: 05 Jul 2013 Location: Illinois Points: 1146 |
I love all of the custom stands! Any damage to the gears in the final drives? Always was curious if those teeth ever wore down much over time from plowing and the like. Also, did you leave the shift tower alone, or did you bore it out for a 2nd shifter pin (I remember this discussion from previous but wasn't sure how it ended up)?
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8447 |
gg, folks,
Ok I did find a couple chipped teeth on the outer edge of the upper gear that drives the bull gear. They were not where the bull gear meshes so I have no idea how that happened. Anyway I am going to run it as is. I really did not see any tooth wear. But I may not be a good judge either! ![]() I did drill a second hole in the shift tower and put in a pin on that side also. Seemed a lot less sloppy! Should be a positive improvement. Those shifters see a lot of action! I did get the hand clutch cross rod installed and locked down. Installed the cover on the hand clutch with gasket. Working on the outdoors paint booth today. We may get a couple days next week where I can dob on some primer and maybe top coat! Regards, Chris |
Oh you did do the 2nd pin hole, nice! Have been leery of drilling that second hole in mine, lest getting it out of alignment and making it hard to shift. Did you drill it straight thru from one side to the other? Any "fitting" required afterwards?
gg,
Yes drilled it straight thru. It did not drill hard. I did not have any issues with any binding. Maybe lucky. I dont think so just enough remaining slop to allow it to function. I do have some picture in this thread. Good luck! Regards, Chris
Folks,
The WD45 castings are close to being ready for primer! Paint is always a major milestone on one of these tractors for me: ![]() Outside paint booth has been rebuilt with some PVC for added structure: ![]() ![]() Took the tail light apart welded up a extra hole in the top, and will put that into the E-tank for cleaning. Has nice original red glass lens. Regards, Chris
Edited by Sugarmaker - 26 May 2019 at 8:28pm |
gg,
Here is the pic of the hole for the extra pin in the shift tower: Colder here today. Happy Memorial day! We plan to get to some of the family grave sites today. I also got a picture, from my cousin Jerry, of a person I believe is my Great, Great Grandfather J. R. King. The picture must be from 1880-1890 time frame? Ok I was having a little fun with him too! ![]() Regards, Chris
chaskaduo ![]() Orange Level ![]() Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Thee original ZZ Top. He would probably chuckle at the glasses too.
Dave(inMA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Chris - glad to see your paint booth is back in business. I gather that you're removing old paint from the castings using a powered wire brush? That's a ton of work! I'll bet that getting primer and a coat or two of paint on that section of the tractor will feel like a huge step toward being done!
WC, CA, D14, WD45
Chas, Dave, Folks,
We been having fun with the old picture! Speaking of pictures I keep snapping a few for the continuing story of the Old Allis and just day to day stuff too! Weather was perfect, and not much wind. Cleaned the rest of the Allis castings and wiped it down with grease remover. Wow was it dirty. Figured I might as well shoot some primer: ![]() I used the large bolts under the tractor to lift it and then I removed the support for cleaning and paint. ![]() I think we have turned the corner! ![]() Throw in a couple brews and a campfire to finish out the evening too! View from my camper: ![]() ![]() Hope things are good out there in Orange Land! Regards, Chris |
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18923 |
WOW, that first pic of the fire,,,,,,,I thought they were BIG logs on there. Seems it's only a pallet. WHEW....
Did you think (or a case of CRS?) to put drains in the lower pans for the final drives?? I didn't see any. Tooooo late now. |
Ted, Folks
I didn't do the plugs in the bottom of the pans. I guess I never plan on changing the fluid! ![]() Regards, Chris
Strokendiesel002 ![]() Silver Level ![]() ![]() Joined: 04 Apr 2019 Location: 53158 Points: 252 |
Chris,
Awesome project and work! Came across your thread a few weeks ago and read a few pages at a time until I was caught up. Since catching up, I really look forward to logging in and seeing what progress you've made, and story you or the others may share :) Thank you for sharing this for all to see and good luck on the final stretch! Jimmy
Jimmy,
Thanks! I guess its become my blog of sorts. And also some therapy for me, doing these old machines. This one had been used hard, broken, repaired, and sent to the auction! I guess it was not a diamond in the rough, just rough! ![]() How am I going to get those new rear tires back from the grandson?? Regards, Chris
Well that's an easy, yet painful answer... buy him a set :)
Jim you just confirmed his fears.
Guys,
I was a afraid of that answer on the tires! Today was prep and paint parts between the rain drops! Still in scuff the rustoleum and primer with the ureathane mode. Basic blocking and tackling. Painting is a love/ hate thing with me. Regards, Chris
MDWilliams338 ![]() Silver Level ![]() ![]() Joined: 19 Nov 2018 Location: NC Points: 476 |
Chris ..that primer looks good and you’ve got better paint weather than what we have down here in NC ‘cause it went from warm to hotter than ...well you know,in just a matter of a couple days! I mean we literally got bamboozled on Spring,had it for a few days and then just straight into Summer we went. I love doing that first run of primer,makes me feel like all that prep work has paid off,like climbing a mountain then starting to come down the other side.
It isn’t how you die.It’s what you live for.-Daniel Boone |
MD,
I was thinking of you and your Dad working on the cleaning process on your tractors, as I was using the needle scaler on the castings. Getting more used to using that tool too. Some of the needles came out. I just peened the heads over again and put them back in. I get overwelmed with the number of pieces that need touched on one of these tractors! Seems never ending. About 1/2 done with new primer. Stay cool down there! Weather seems to be getting a lot wetter here. But we dont have the flooding like some areas. So we can be very thankful for that. Hope things are good in Orange Land! Regards, Chris
Yessir,dad says the same thing when he’s running the needle scaler but some areas it’s perfect for.He has this roll-around stool he sits on and he just scoots all around the frame when he’s cleaning...scale/clean a bit,spit tobacco,drink a Pepsi,slow and steady is his routine 😁 And I ain’t gonna complain about our weather anymore after seeing what just happened in the upper and Midwest getting hammered with tornadoes. |
Folks,
Prepping work has me in a head lock! Parts to be primed: ![]() Working on putting the throw out bearing and fork back in. Regards, Chris |
exSW ![]() Orange Level ![]() Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Not raining up there? I've been chased in three times today.
exSW,
I was rained out twice and gave up on paint work today. Tractor pull at Sagertown Saturday! Folks, So some questions: I have installed the new pilot bearing in the flywheel, light press fit. Prior to that I checked and made sure it fit on the end of the drive shaft too. Installed the flywheel, it was a light press fit and pulled in easily to the end of crank with the four cap screws. Tried to find the torque for those 4 bolts, I put on a little blue lock tight and went to 60 ft lbs. ( I did see a post that said 40 ft lbs, so I may over torqued them?) ![]() Next question: Here is the old pressure plate in front of the new one. I think the previous owner had the clutch, pressure plate and throw out bearing replaced recently, all of those look pretty darn good to me. The pressure plate has a couple of blue spots about the size of a pencil the surface still has some of the grinding marks and is smooth. I am inclined to reuse this old pressure plate. My plan was to use a 9 spring which is what I thought I had but when I opened the box it is the same 6 spring type. Have to sort that out tomorrow. ![]() On the clutch plate the old clutch is .010 thicker than the new clutch and doesn't seem to have hardly any wear. Looks same as the new one! Again I think I may just use the old clutch! Throw out bearing: Called Sandy Lake and talked with Bill. He was kind enough to walk me through the inspection procedure on the throw out bearing. Push it back towards the back of the tractor and check side movement. Hardly any. Again plan is to reuse this old throw out. Questions comments and or concerns are always welcome. Yes I have the new clutch and pressure plate setting here. I also know its a pain to change these later. But I am also frugal. ![]() On a positive note I also located my clutch plate alignment tool !I had not used it in more than 40 years. Looking forward to using that to align the clutch plate with the pilot bearing! Regards, Chris Edited by Sugarmaker - 30 May 2019 at 9:28pm |
Chris I’m partial to being frugal too and from what I can see in those pics I’d put the old setup back in and save the new clutch (pressure plate looks sharp to me) especially if they’re were no problems with it before the tear down.Are they’re any plans to pull with this tractor?
MD,
Yes I am planning on a few Antique tractor pulls, if it will hold together that long! Another different question: Were the egg tail lights black or PO on a WD45? The good used light I got has a little original black paint under the orange. Regards, Chris
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
If you can send them back that looks like the right move but if you can't return then install the new parts keep the good but used parts for the next tractor. Look in your Allis manual it has the torque in it for the flywheel, OK I looked it up for you it's 50'lbs.
I lined up my clutch by eye and she slid right in. I had both the flywheel and pressure plate ground at the local shop, so I didn't get to cheat by going into the old grooves. Don't let that tool hold you up!
Claus ![]() Orange Level ![]() ![]() Joined: 09 Dec 2009 Location: Hebron In Points: 1154 |
Love all of your hard work, tractor is looking so nice even in the state it's in in the last photos.
Orange folks,
Thanks guys! So does anyone think the 9 spring pressure plate is a better option? I believe these 9 spring units are whats used in the D17 tractors. Its about $50 more for the 9 spring unit. We ran these old WD45s for years and pulled hard. I dont ever remember the standard clutch slipping. Don, Thanks for the torque values. Guess I just did not look far enough! Claus, Thanks for the kind words. So many parts, seems so little time!:) Regards, Chris |
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4010 |
Chris, later 45's had the 9-spring unit. Don't know the serial no. break. I put 9's in both of my 45's that I have been into. Did I need to? Really don't know but they don't slip! The only clutch slipping I've had was with my Grandpa's 52 WD. Suspect the hand clutch in this one.
Mike,
Thanks! I think I will get the 9 spring pressure plate. And use the old clutch plate. Regards, Chris
