WC Speed Patrol battery cable
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Topic: WC Speed Patrol battery cable
    Posted: 13 Dec 2011 at 9:57am
My Wc Speed Patrol needs the battery cable that runs from the battery box to the starter motor.  The battery box is located on the left side just in front of the rear axle and behind the support mechanism for the two large lift wheels that lift the blade.  Where does the cable snake along to get to the starter motor from the battery box?  Does it stay on the outside of the channel iron or go inside?  Thanks.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 6:44pm
On mine it jumps over the channel at the battery box then follows inside the channel and comes up beside the starter. No idea if it's the original location or not.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 9:10pm
Farrell, If it's like a WC it actually runs down the top of the left side frame rail with two clips that hook over the frame to hold it in place. It was nice seeing you the other day. Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 11:08pm
We offer a new Battery cable for the WC if interested. If you need one made specifically for your application, we can do that to! Just need the length and I'll build a new one for ya...
Steve@B&B
