WC Sherman Pops out of Low Range
Phil N View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil N Quote  Post ReplyReply Direct Link To This Post Topic: WC Sherman Pops out of Low Range
    Posted: 18 Jul 2011 at 2:24pm
I have a '48 WC with a Sherman Aux Overdrive transmission between the standard transmission and the rear end. The High position works great but the low position pops out of gear. I have been using a bungee cord to hold it in low position. I had the top cover off when I changed the gear oil and couldn't see any obvious problem. What are some of the possible issues causing this unit to pop out of low range? Thanks in advance for your input.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2011 at 5:14am
I cant tell you for sure other than everyone around here has a bungee cord holding them into gear!!!
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2011 at 7:35am
Mine has notches to lock it in you have to pull up on shifter to get it to move. It is overdrive also I guess I thought they were all like that I wonder if mine is later one or not sherman.
This page was generated in 0.250 seconds.
