WC running rough while Idling
farmboy59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy59 Quote  Post ReplyReply Direct Link To This Post Topic: WC running rough while Idling
    Posted: 21 Nov 2020 at 6:40pm
Got an Unstyled WC that runs smoothly under a load. However if it's just sitting in neutral running the throttle surges. Carb and timing adjustments didn't change anything. Gonna adjust the valves and see if any are sticking tomorrow. Any other suggestions?
36 WC, 50 WD, 51 CA, 55 D-14, 59 D-17, 62 D-19, 73 610
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2020 at 8:23am
Idling and surging could be a small vacuum leak somewhere. Spray a little carb cleaner around the intake manifold, Carb base, and where the intake meets the cylinder head. If you hit a spot where all of a sudden the engine smooths out and the surge is gone, you've probably found your vacuum leak. Also could be a little dirt in the idle circuit or a low float setting.... HTH
Steve@B&B
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2020 at 4:00pm
I'm going to say it's a carb issue,  adjusting the valves will do nothing for a surging engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy59 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2020 at 9:02pm
I should add that the carb is off of a perfectly running D-17. Before the carb swap I sealed the manifold gaskets with high temp permatex just to rule it out. I'll be putting the original carb back on once I go through it again and see why it wouldn't stay running with it on there. I figured it was a fuel issue as my D-17 will surge while working if the load screw isn't out enough. May end up having the manifold planed and install new gaskets.
Edited by farmboy59 - 22 Nov 2020 at 9:03pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2020 at 9:22pm
Check the distributor shaft for bushing slop, and check the advance mechanism for proper operation, either of those may give you similar issues.
