WC Road Gear
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Topic: WC Road Gear
    Posted: 25 Jun 2018 at 6:59pm
WC currently runs 11 MPH with stock governor spring and 12/28 tires. If I go up to a WD 45 gov. Spring roughly how many MPH will I gain? Thanks
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2018 at 8:05pm
1.1 mph
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2018 at 10:57pm
Ok the rules for local tractor drive say 12 so that should get me there!
Edited by KY - 25 Jun 2018 at 10:57pm
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2018 at 10:59pm
i used a taller rear tires; for tractor rides' it made it a lot faster.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2018 at 11:14pm
These are the equivalent of 13.6 -28
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2018 at 12:03am
16.9-28 you won't need to run the motor that hard' or even 14.9 will sure help
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2018 at 5:50am
Iv'e gone about 1500 miles with 14.9's on a WD45.   Farmall M will go flying by but I still can easily stay with the majority.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2018 at 7:14am
With a legit D-17 governor spring in that WD45, you will keep up to that "M" Farmall.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2018 at 9:05am
It's a WC
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2018 at 9:06am
Yes it makes a big difference
