WC Exhaust
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: WC Exhaust
    Posted: 16 Jan 2012 at 8:36am
Did all WC's exhaust out the side, or did later ones come through the hood? If they did all come out the side, is anyone casting any?
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 8:54am
The side exhaust was used on the Distillate-fueled versions of the WC.  And WD's as well.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 12:18pm
Unit  3         We have  new  side  exhaust  manifolds .    Tony
         tony@tonystractors.com
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 12:27pm
Do you have both side and top exhaust maifolds?  Ours has a plate over the side exhaust and a muffler out through the hood.  I have not seen restoration manifolds yet with both exhaust ports.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 12:47pm
Pretty sure the later WC's came straight up like the WD's.  The manifold are being reproduced and you can buy just the "elbow" piece for the gas model.  The keroscene is not yet reproduced.
JimD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 4:17pm
If you take that plate off, there should not be a connection to the exhaust under it. It's made like the B-C manifolds with the data plate. The manifolds were either side exhaust or top exhaust, no combination. If yours has an opening to the exhaust under that plate it is burned out.
 I have a manifold with the plate on the side that is in good usable condition.
Edited by CTuckerNWIL - 16 Jan 2012 at 4:19pm
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 1:09pm
hi tramway guy. my family swapped horses and mules for what i was told was a new 42 wc back in the day. i had always assumed that all wc's were side shooter exhaust till later years or at least after 1942. i never considered our wc was a distillate model per your thread. a number of other  farmers in the old Blough Neighborhood where we farmed had brand x tractors and they had those little what they called "reserve tanks" right behind, or included in the main fuel tank to these tractors. i was born in 49. i know now that these werent reserve tanks but starter tanks for those engines that could burn something other than gas............start em on gas and then switch over.......our wc had no such switchover mini tank although it had a set of canvas curtains that could be closed during cold weather. without a switch over tank for these side shooter distillate models how did the operator light off his wc on those sub freezing ohio winter days? likewise, ive seen a ton of wd"s but never one with a side shooter......bolivar boy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 2:14pm
JimD
 Jim, The side exhaust was for the Kerosene burner or All Fuel. The only WC's I have seen with a straight up exhaust had a nasty looking big round hole for the muffler to go through, probably cut on the farm with whatever was available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 2:18pm
Bolivar, If your WC didn't have a starter tank it  may have had the hood replaced or maybe it was a higher compression meant to run on gas only.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 3:35pm
thanks tucker. the hood was original. i'll just tell the grandsons we had a hopped up 201 !....
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 5:34pm
My styled WC has a straight up exhaust and no starter tank holes, but I guess it could be a WD hood. It has a hole for the shutter crank.
