Water pump play
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Topic: Water pump play
    Posted: 14 Jun 2017 at 8:24pm
Today I was servicing the 6080 getting ready to clip pastures and the fan had a little play. About 1/8-3/16" at the end of the fan blade. At what point do you replace the water pump. We have one coming and I'm not going to run it. Just curious if there's some measure that you all go by. Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 9:27pm
I go by feel.  When in doubt, change it out.  You don't want the fan to take out the rad when it lets go.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 9:27pm
Any play it gets replaced, before I have to replace or repair rad.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 10:56am
If there is play the seal is probably leaking coolant to the bearing badly and neither the seal or the bearing will last long.
Gerald J.
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 12:14pm
Working on my 7060 now due to the same issue. Look really close at the condition of your pulley while your in there. I had a tin pulley that looked really bad. Ordered a nice new cast one.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 1:18pm
Now! unless you want a new radiator too!
This page was generated in 0.077 seconds.
